NI-RIO 2.0.2 Installation
I just downloaded the NI-RIO 2.0.2 update and tried to install it on TWO platforms. It says "Installation Successful" but within the MAX it still shows 2.0.1 on both machines. I had already installed 2.0.1 when it was released.
I tried uninstalling and Installing it again but, same results. If I try to install without uninstalling, it says "Update Installation Failed"
"Error on Verifying product for update to CompactRIO module support. Please reinstall it before trying to run the application again"
Then I opened up my project and all references to the cRIO modules were missing!Smiley Mad
Currently uninstalling / Reinstalling FPGA/RIO drivers... has anyone encountered this before?
Message Edited by ashm01 on 05-15-2006 09:59 AM
Message 1 of 8
(4,158 Views)
NI-RIO 2.0.2 is really CompactRIO Module Software 2.0.2.  So, the MAX listing for NI-RIO will actually still show 2.0.1.  If you uninstall, you need to start again with NI-RIO 2.0.  This is because 2.0.2 is just an update and needs 2.0.1 installed on your machine to work.  Therefore, you uninstalled all of your cRIO support files but never got them back.
Brian Ruhmann
CompactRIO Software
Message 2 of 8
(4,147 Views)
Thanks for the quick reply, I hadn't uninstalled NIRIO until I got the messsage for an unsuccessful install...
I reinstalled NI RIO 2.0, then ran the patch 2.0.1 and then 2.0.2 (Not expecting any change in Max)...Looks like we are back to normal.
ThanksSmiley Happy
Message 3 of 8
(4,143 Views)
There should actually be an entry in MAX for CompactRIO Module Software.  In the future, we may remove the entry for NI-RIO and replace it with an entry for the driver.  This way, we can upgrade the driver and the module support seperately without causing version confusion like this.
Brian
Message 4 of 8
(4,140 Views)
Does the NI-RIO 2.0.2 also correct bugs on 7833R???
thanks
Message 5 of 8
(3,994 Views)
thanks
Message 6 of 8
(3,993 Views)
CompactRIO Module Software 2.0.2 does not contain any modifications of the 78xxR target plugins for LabVIEW FPGA when compared to NI-RIO 2.0.1.
Message 7 of 8
(3,988 Views)
Thanks for your answer.
regards,
Message 8 of 8
(3,963 Views)
