NI RIO update
Seasons greetings to all,
Just got the Q4 LV Professional Development update and after browsing through the documentation the NI-RIO update seems to be my only relevent update.    However after installing from the NI-RIO disk to the desktop then from MAX to the designated target which is a cRIo-9012, 9102 chassis.   In MAX the target shows up under remote systems but none of my programs will run because it appears that there is no communication with the fpga chassis.    Did I do something wrong?
(3,688 Views)
Why do you say there is no communication with the FPGA chassis?  Can you see the FPGA under Devices and Interfaces when you locate your cRIO under Remote Systems in MAX?  You might also try recompiling your FPGA code with the new driver and then deploying it to the FPGA that has the newest NI-RIO driver.
Donovan
(3,647 Views)
