Service Error 1053
I have created and exe with Labview (7.1) and have turned it into a service using the "Creating a Windows NT Service Using LabVIEW"  tutorial.  The program and its interface program run fine when I don't try to start it as a service.  When I try to start the service, it does start up fine, but it then gives error 1053: the service did not respond to the start or control request in a timely fashion.  When this happens, the service stops.  I know it is starting fine because my interface program connects to it just after I start it up but disconnects when the error occurs.  Does anyone know why this is happening and how to fix it?  Thanks.
(3,967 Views)
I was unable to find helpful information about the service tutorial.  I did find this Microsoft knowledge base that discusses how to make and application a windows service.  I will look for more information and let you know if I find anything relevant.
Eric A.
Distributed I/O Product Support Engineer
(3,953 Views)
