NI RIO9074 Power Supply
Hello
I have Compact RIO cRIO-9074 and trying to give power to it.
In the manual, it says 48W and 24VDC.
Can I use Hewlett Packard E3630A DC Power Supply 23V 0.5A for this?
I just wanted to make sure that I don't blow up the kit.
Thank you so much
(2,991 Views)
If the datasheet says that the system needs 24V and 48W, you never can use your power supply.
The problem it's not on the voltage. Your power supply should give 48/24=2A. Since it only gives 0,5A you can turn on the CRIO.
Software developer
www.mcm-electronics.com
PORTUGAL
(2,969 Views)
Hi Hinewwiner,
Here are the power specifications from the 9074 manual
Power Requirements
Recommended power supply ................. 48 W, 24 VDC
Power consumption................................ 20 W maximum
Power supply input range....................... 19 to 30 V
Also from the maual it states that the cRIO-9072/9074 has one layer of reverse-voltage protection.
The 48 W /24 V is the recommended power supply.  You should be fine with the 23V power supply at 0.5A.
Basset Hound
(2,947 Views)
The voltage and current values you give for your Hewlett Packard power supply will yield a maximum of 11.5 W. The cRIO-9074 requires at maximum 20W with all module slots in the chassis occupied. However, to just turn on the controller with no modules connected, you only need 6W. Thus your power supply will work fine to just power the controller and FPGA backplane. But once you start trying to power modules, you may run into a problem. You will not have adequate power to supply all 8 modules, that much is certain. Exactly when in the process of adding modules you will begin to see problems depends on a number of factors including which modules you insert and how many. My best recommendation to you would be to not power more than just the cRIO-9074 with this power supply. Once you add modules, upgrade the supply to something that can supply at least 20W.
I hope this helps. Feel free to reply if you need any clarification.
Sincerely,
Asa Kirby
Message Edited by Asa_K on 05-19-2008 01:50 PM
Asa Kirby
CompactRIO Product Marketing Manager
________________
Sail Fast!
(2,928 Views)
Thank you so much for all your help.
(2,917 Views)
