NI-SCOPE Multiple Measurements problem
My VI is attached. It makes multiple measurements of every line of a device for calibration purposes, the device is then attached to equipment that it is testing, and makes measurements on every line again.
This VI works fine in making the measurements for all of the calibration, but when it gets to the second phase for the actual testing it won't perform averaging or integral measurements. While it creates the instantaneous data just fine, the data results for the integral and the averaging are returned as NaN's.
The most mind-boggling part is - the device has measurements being taken on two channels; one of the channels, the averaging works fine even in the testing phase. It's only one channel which isn't working properly, only averaging and integral measurements, only in the second phase of the VI (when their configurations are set up to be effectively the same).
Any insight into what could cause this would be very much appreciated.
Thank you,
Wolley
(3,347 Views)
Accepted by Wolley
The code you are working with is rather involved.  Would it be possible for you to simplify your code to better isolate the problem area and make troubleshooting easier?
Also, what do you mean by every line of a device?
James K.
Applications Engineer
(3,324 Views)
I actually found the error - it was a silly mistake, forgot to copy over a couple of values for configurations of the measurements.
Sorry for taking your time.
Wolley
(3,318 Views)
Is there a way to remove threads?
Moderators?
(3,316 Views)
