NI SCXI 1314
I was reffering to the one in MAX.
Speaking of Labview, the one there doesnt work all that well either 🙂
Aquaphire
---USING LABVIEW 6.1---
Message 11 of 21
(1,630 Views)
What exactly is happening in MAX?  Are you getting any kind of error from the Null Calibration Utility?  Can you attach a screenshot of what you are seeing?  Did you make sure that you have the strain gauge wired correctly, including shunt resistor connections?  What kind of strain gauge are you using (Quarter-, Half-, or Full-Bridge)?
Sean C.
Message 12 of 21
(1,624 Views)
Hey sean, this is exactly what happens.
I set up everything correctly, lets say, yesterday. Today I want to run an experiment so i want to recalibrate my strain gauge.
I open MAX, right click on the strain gauge, properties, then click on "calibration". From there, I wait till the value more or less stabilizes, and click on "null correct". I ignore "Shunt" because I have no idea what it is, and check my value by clicking on "update".
Everythign seems to be going normal, meaning i read around "-0.03, 0.02. 0.23, -0.01, etc..."
I click on exit, then Finish.
Then I enter "test panel", and somehow the value has now reached -1326....
why??
thanks
Aquaphire
Message 13 of 21
(1,622 Views)
sorry, forgot to attach. This is the configuration I have.
Aquaphire
Message 14 of 21
(1,621 Views)
and this is the calibration screen after one config... I don;t understand why it won't nullify!
Aquaphire
Message 15 of 21
(1,620 Views)
I discovered that sometimes if I don't calibrate it hovers around 1.0 ... I'm really not sure what to do. please help!
Aquaphire
Message 16 of 21
(1,610 Views)
This is strange...  Go ahead and try upgrading to NI-DAQ 6.9.3 (you can download this from: http://digital.ni.com/softlib.nsf/websearch/50F49E43A22C0D2186256BF3006B9A96) and see if that helps.  Do you have another SCXI-1520 that you can test this against?  It sounds like the calibration constants are not being stored properly...
Let me know your results...
Sean C.
Message 17 of 21
(1,601 Views)
Hey sean,
It fixed the problem (yipee), but now my VI can;t launch. All the SUB-VI's that it used cannot be found:
AI group config
AI hardware config
AI buffer config
AI clock config
AI parameter
AI start
AI clear
AI read
AI read scaled array
Convert Strain Gauge reading
Convert Strain Gauge reading (scalar)
SCXI Strain Null
Device reset
etc. etc. etc.... 😞
HEEEELP
Aquaphire
Message 18 of 21
(1,598 Views)
oko k. i fixe deverything!! its all good now.
*end thread*
Aquaphire
Message 19 of 21
(1,594 Views)
Out of curiosity, what did you do to fix that problem with the missing subVIs?
Sean C.
Message 20 of 21
(1,586 Views)
