NI-Scope Vertical Range
What does exactly the vertical range value from the NI SCOPE VERT. vi change?
Thank you,
Ninskaya
(2,941 Views)
Vertical range is the peak-to-peak voltage span that a digitizer can measure at the input connector.
Have a look here for more details:
http://zone.ni.com/devzone/conceptd.nsf/webmain/DADB84DA3A34666486256F3C007C2D8A
Greetings
Alex
NI Switzerland
(2,933 Views)
Thanks a lot.
Ninskaya
(2,927 Views)
