NI-Scope Vertical Range
What does exactly the vertical range value from the NI SCOPE VERT. vi change?
Thank you,
Ninskaya
(3,268 Views)
Vertical range is the peak-to-peak voltage span that a digitizer can measure at the input connector.
Have a look here for more details:
https://www.ni.com/en/support/documentation/supplemental/17/specifications-explained--ni-oscilloscop...
Greetings
Alex
NI Switzerland
(3,260 Views)
Thanks a lot.
Ninskaya
(3,254 Views)
