05-05-2017 12:01 PM
Dear all,
I try to find a VI or property node with which I can set programmatically the Mode of the Trigger Settings so that I can chose between Norm, SGL and Auto – see attached picture.
I know that I can use for example the "niScope Configure Trigger (poly).vi", but this enables me only to set trigger coupling, trigger slope, trigger source and so on, but not the trigger Mode.
I hope somebody here can tell me where this option is hidden.
Solved! Go to Solution.
05-07-2017
03:03 PM
- last edited on
12-13-2024
10:33 AM
by
Content Cleaner
I think a combination of the information at this link: http://www.ni.com/product-documentation/3382/en/ and a case structure should be able to do what you want - identify the different VIs that produce different triggering types, or the place where that dropdown menu is wired to, and then implement whatever change you want, possibly using a case structure.
05-08-2017 02:20 AM
Thank you for your reply!
You write
I think only the "niScope Configure Trigger (poly).vi" defines trigger types.
From these trigger types I use the "Analog Edge Ref Trigger" with the following settings:
Type: Edge
Coupling: DC
Source: ch 0
Slope: positive
Mode: Auto
Setting the first four parameters is no problem at all (my program runs well)!
But I also want to set the Mode to Auto.
But how? I cannot find a VI or a property node with which I can do this.
You write
identify… the place where that dropdown menu is wired to
I would love to identify this. However, I cannot see the code/block diagram of the NI-SCOPE.
And I do not see how a case structure shall help here. For sure, I can create a button with these cases but this must be connect to somewhere to force my oscilloscope to be in the Auto Mode (and not in SGL or Norm – the behavior is very different).
Is there any way to select somewhere the Mode? Perhaps this is very well hidden in LabVIEW and different names are used so that I cannot find it. Or is this option really not implemented in the NI-SCOPE VIs?
If so, how can I imitate the different Modes?
05-08-2017
02:30 AM
- last edited on
12-13-2024
10:37 AM
by
Content Cleaner
You write
Ah. Well, my first point was related to the poly VI you mention - what are the other options? The documentation here lists immediate, software, hysteresis, edge, window, video, and digital triggering, but I guess you already looked at the other options.
With regards to your second block-quote - my apologies, I didn't know that the NI-SCOPE block diagram was locked/removed. Reading the documentation made me believe that these must be accessible.
Now I'm really rather confused. Are you completely replacing the NI-SCOPE program? It sounds rather like that is your only option if you can't make changes to the existing BD, but perhaps I'm wrong again?
05-08-2017
03:17 AM
- last edited on
12-13-2024
10:38 AM
by
Content Cleaner
Wow – that was a quick reply. Thank you!
Thank you also for your list with the options. I took a look there but I could not find anything helpful.
Yes, it is a pity that the NI-SCOPE block diagram is locked. I am even not sure if the NI-SCOPE soft front panel is written with LabVIEW. I asked once another question about NI-SCOPE and somebody wrote here that it is not written in LabVIEW (similar answer here).
Perhaps this is the reason why I cannot find something in LabVIEW to set the Mode...
Yes, you are right. I used the NI-SCOPE soft front panel to see what settings I have to use. Then I wrote my own LabVIEW program which replaces the NI-SCOPE program (and which is optimized to my needs).
My program is based on this screenshot here (from this post here; somewhere one can find the code belonging to the screenshot).
Unfortunately, as said, I cannot set the trigger mode in my program and I do not see with which VI or property node I can do this (I even do not know if this is possible at all).
05-15-2017
02:52 AM
- last edited on
12-13-2024
10:38 AM
by
Content Cleaner
It seems nobody knows a solution for my problem 😞
But perhaps somebody can give me hints how to program a workaround to achieve that my program does the same as the NI-SCOPE Soft Front Panel when the trigger mode is set.
My NI-oscilloscope is connected with a wire to some source to measure the voltage.
Depending on the mode, following happens:
SGL: If my voltage exceeds the trigger level, a measurement is started once. The trigger has to be armed manually again for the next measurement. So far, I do not need this behavior, so this mode is not so important for me.
Norm: The voltage is measured all the time – when I disconnect the wire, the last measured curve is still visible on the NI-SCOPE Soft Front Panel.
Auto: The voltage is measured all the time – when I disconnect the wire, the last measured curve disappears from the NI-SCOPE Soft Front Panel.
My program, which is based on the code visisble here (post here), is always in the Norm-Mode. But I want it to be in the Auto-Mode. How can I achieve this?
05-15-2017 03:44 AM
05-15-2017 08:02 AM
I like your idea because this is something I could use. But there is no timeout error 😞
05-15-2017 10:23 AM
05-15-2017 11:11 AM
OK, I'm going to let you off the hook
the SFP for NI Scope fakes everything about that enum <Auto, Norm, Off> and initiates a read? once, once while triggered or just once, once, once......
