Need the Block Diagram of NI-SCOPE Soft front Panel
Hi Friends,
I am using Labview to control NI PxIe-1073 box.  In the folder of Labview, I found a very useful front panel that can control our device, but i need to change something of it. As shown in the attachment.
The problem is that I am having a hard time finding the block diagram to get the codes. I need to add the codes into a blank VI and then edit it.
Is anyone has the codes (Block Diagram) for the use of NI-SCOPE Soft front Panel? Or someone can show me how to import it to the Labview?
Thanks so much for your kind help.
Perry
(3,232 Views)
Accepted by topic author Perry_Liu
I doubt that the code for that is available - it may not even be written in LabVIEW.  The NI-SCOPE examples that ship with LabVIEW (look in the Example Finder under Hardware Input and Output -> Modular Instruments) demonstrate all the available functions, and there may be an example there that will work as a starting point for you.
(3,229 Views)
