Need the Block Diagram of NI-SCOPE Soft front Panel
Hi Friends,
I am using Labview to control NI PxIe-1073 box.  In the folder of Labview, I found a very useful front panel that can control our device, but i need to change something of it. As shown in the attachment.
The problem is that I am having a hard time finding the block diagram to get the codes. I need to add the codes into a blank VI and then edit it.
Is anyone has the codes (Block Diagram) for the use of NI-SCOPE Soft front Panel? Or someone can show me how to import it to the Labview?
Thanks so much for your kind help.
Perry
(3,175 Views)
Accepted by Perry_Liu
I doubt that the code for that is available - it may not even be written in LabVIEW.  The NI-SCOPE examples that ship with LabVIEW (look in the Example Finder under Hardware Input and Output -> Modular Instruments) demonstrate all the available functions, and there may be an example there that will work as a starting point for you.
(3,172 Views)
