NI ServiceLocator is not running on OS X
Here's my nilxid.plist.
Any progress on figuring out what's going on?
-Scott
@Kevin F wrote:
Hey Everyone,
Do you see the nilxid.plist in your Launch Daemons?  I think that after 2010 the nisvcloc will not show up in your activity monitor since it has been bundled into the Web Services.  The only way you will see those folders is if you have older versions of LabVIEW installed (2009 or earlier).  I am currently working on getting a machine up and trying to reproduce the issue you are having.
Message 21 of 29
(1,718 Views)
Opps, the third line got cut off in the PDF. Here it is:
/Library/Application Support/National Instruments/NI-VISA/niLxiDiscovery.app/Contents/MacOS/niLxiDiscovery
Message 22 of 29
(1,716 Views)
Any progress on figuring out this problem?
-Scott
Message 23 of 29
(1,696 Views)
No resolution on LV2010, but I can tell you that LV2011 as expected.
Message 24 of 29
(1,688 Views)
I can also verify that the OSX 2011 LabVIEW evaluation version does not have this bug.
-Scott
Message 25 of 29
(1,674 Views)
Hey Everyone,
We are having trouble reproducing the issue on our end using LabVIEW 2010 so it has been difficult to develop a work around.  There has been a fix put into LabVIEW 2011 to correct this issue.
Kevin Fort
Principal Software Engineer
NI
Message 26 of 29
(1,650 Views)
Hello, I also I have the same problem with 2009 lab when I open the view finder example an error message appears that says, "the NI Service Locator is not running. You Will Not BeAble to browse by directory structure".
Message 27 of 29
(1,625 Views)
sorry you are having this issue, have you tried restarting the NI Service locator? You can follow this link to a KB on how to do it
http://digital.ni.com/public.nsf/allkb/8C00F1144B2CD73E86256DEF00698AC3?OpenDocument
good luck
BeauH
BeauH
Message 28 of 29
(1,610 Views)
The instruction you link to are for Windows, not OS X.
-Scott
good luck
BeauH
Message 29 of 29
(1,606 Views)
