NI-Switch disconnect error
I am working with the PXI-2503 card and i am working with someone else code and I was wondering if someone can guide me on trouble shooting this issue. I don't know much about hardware interface, but i am learning.
i have this error message in my code.
Krispiekream
(3,102 Views)
Accepted by krispiekream
When you are using NI-SWITCH drivers, you need to make sure that there is some explicit path set up between the two channels. This won't happen if the channels refered to are on different devices, check for that as well as check for the exact channel name as it is set up in Measurement and Automation Explorer.
Applications Engineer
(3,076 Views)
