NI USB-6008 can measure AC voltage
Now I am doing a project, but not sure whether DAQ can measure AC voltage or not, the DAQ we are using is USB-6008.
(3,799 Views)
Yes it can measure AC voltage of range +/-1 to+/-20 volts.
(3,790 Views)
It's +/- 10 volts and important for ac is the sample rate of 10kS/s. See the specs.
(3,764 Views)
yeah i m sorry to misinterpret sheet .. rightly said above it can measure in range of +/- 10 volts .. any way focus on sampling rate and resolution.. thats more important..
(3,750 Views)
Accepted by Jacksparrow
Yes, it can measure AC in range of +/- 10 volts, and have a sample rate of 10kS/s.
NI Application Engineer
(3,706 Views)
thank you for your help
(3,678 Views)
