NI USB 6009 10 V Ausgang
Hallo zusammen,
ich verwende eine NI USB 6009 Karte und möchte mittles LabView ein 0-10V Spannungssignal an einen Druckregler ausgeben. Die NI Karte kann allerdings analog nur 0-5V ausgeben. Gibt es eine Möglichkeit, die beiden AOs zu kombinieren, um einen 0-10V AO zu erhalten?
Danke und Grüße
(2,859 Views)
Hi ak2697,
it is not possible to output 10V from any USB Powered device. It is not technically possible.
Best,
Andrzej
(2,820 Views)
Accepted by topic author ak2697
Hi ak,
you can use a converter (aka OpAmp) to amplify the AO signal of your NI6009 by a factor of 2.
Or use something like this (type DB68).
Note: this is an English forum and so you should write your questions in English. Ein deutschsprachiges Forum findest du hier.
(2,815 Views)
Hi GerdW
Thanks for the answer. I'm sorry that I asked in German, I didn't know that.
Unfortunately I have no idea how to install or connect such an OpAmp. But in itself that sounds exactly what I was looking for.
(2,795 Views)
Hi ak,
So you don't know about basic eletronics circuits?
Then buy the tool (or similar ones from other suppliers) I linked to in my last message!
(2,791 Views)
