NI-USB-6009
I am trying to use NI-USB-6009 new part I ordered and it's not working. when I connect it to my laptop, I got the attached message. I can't even see the device in NI MAX. what would be the issue please if someone can help with that?! Capture.JPG
(1,492 Views)
Hi Omar,
did you read the recommendation in your image?
(1,482 Views)
Where did you purchase this device?  NI? eBay? Other?
aputman
(1,465 Views)
Accepted by topic author Omar-Abdelhameed
Can you see it in Device Manager?
Do you have NI-DAQmx installed?
Are you plugging directly into the USB port on your laptop (no USB hub)?
Have you tried rebooting to give Windows a chance to update drivers?
Do you have another USB cable you could swap in?
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
(1,432 Views)
