NI USB 6210 TTL signal
I am trying to get the NI USB 6210 to talk to a Bio-Logic VMP3 battery cycler through TTL signals and was wondering if someone could direct me to some relevant examples? Basically, I am assuming that the PFI <0..3> ports can accept TTL signals and that the PFI <4...7> can generate TTL signals. Could someone please confirm this? Also, is there an example on the USB 6210 or some related device's signalling capabilities?
Thanks a ton!
(2,679 Views)
Have you even opened the examples that come with LabVIEW? Help>Find Examples>Hardware Input and Output>DAQmx>Digital Generation.
Your manual explains the pinouts.
(2,666 Views)
