NI USB-6215
I'm using a NI-USB 6215 card to power the circuit in the picture (although the same issue occurs with the 6008 card). I'm trying to set the analogue out value to 5 V and more however the Voltage readout won't exceed ca. 3.2 V. The card is fine when not being used to generate a voltage for the current readings. The manual states that this card should be able to handle 50mA and I'm only drawing 6mA. I gather I can use an external 5 V supply which may help but was surprised that this problem was occurring.
Does anyone have any thoughts about this issue?
Regards
Stephen
(3,988 Views)
Attach the manual that says this card can output 50 mA.
When I searched for the specs, I found this https://www.ni.com/docs/en-US/bundle/usb-6215-specs/page/specs.html
It says overdrive current 2.4 mA.
DAQ cards aren't meant to power circuits.
(3,959 Views)
Your circuit would work better if you used a Digital Output for the LED control and sink the current (not source it).
Former Certified LabVIEW Developer (CLD)
Currently using LabVIEW 2022
(3,939 Views)
The +5Vdc terminal on the device will output 50mA but the analog output channels will only drive 2mA.  These devices are not meant to power circuits.
aputman
(3,935 Views)
