error 200220 and cant rename cDAQ device
I have little/no experiencce with labview. but we have a sw made by a third party vendor (made couple of years ago) which im trying to get up and running.
when i run the sw i get the message:
"error 200220 occurred at DAQmx.
possible reason:
Device identifier is invalid.
Device specified: cDAQ2"
i try to rename the 9188xt device in MAX, but seems im not allowed. see attached screenshot.
logged in as admin.
labview 14.0f1
MAX version: 14.0.0f0
9188xt fw: 1.7.0f0
(2,548 Views)
HI JanEgilGlaestad,
It seems the Log In is still available in your screenshot - are you logged in as an Admin when that was taken?
Have you tried configuring your cDAQ via the NI network browser? If you don't have this installed the check the below link:
http://digital.ni.com/public.nsf/allkb/135A9D4370820E9C86257766006AE101
Often a simple solution for this is to reset the MAX Database. This can easily be done by following the instructions in the article below:
http://digital.ni.com/public.nsf/allkb/2C7480E856987FFF862573AE005AB0D9?OpenDocument
Hopefully this will then allow you to rename your device. If not, we can follow some further troubleshooting steps.
(2,506 Views)
Thanks. I think it was the resetting of DB that did the trick. Anyway its working.
(2,497 Views)
I tried the solution above (running "Reset Configuration Data" ) but did not have success. Right clicking on cDAQ-9172 in MAX does nothing.
(2,412 Views)
