NI USB-6251 DAQ
is it possible for the USB-6251 to supply an output to a test fixture while reading the inputs from the same fixture? for example: 10VAC peak to peak out to the fixture, mixed Sine and Square wave signals from fixture to the DAQ box.
(2,694 Views)
Accepted by topic author testech68
Yes. The 6251 has two analog outputs  and 16 analog inputs. Open the example finder and look for examples of both. Under Hardware Input and Output>DAQmx>Syncronization>Multi-Function, there's an example of synched analog input/output.
(2,693 Views)
