NI USB-7855R - "The current target does not support shared variables"
Hi Everyone,
I'm trying to share a few boolean values between a host application and an FPGA using shared variables. However I get the error when trying to build:
I can't seem to find much info about this error, or why the NI USB-7855R doesn't support the SVE.
Any information would be appreciated.
(1,516 Views)
FPGA does not support Shared Variables.  You can just use front panel controls to pass tag data to the host.
(1,510 Views)
I'm currently passing data to the FPGA from the host using the Read/Write Control from the FPGA Interface Pallet and this works, but it's slow.
The write takes about 4ms.
Are you saying I can just drop the FPGA's VI into the Host's block diagram and integrate it like any other VI? I tried to do this the other day and ran into problems. If this should be possible, please let me know and I can explain what was going on.
(1,493 Views)
That is the way to do it.  4ms does seem like a long time though.  It could be from Windows or even the USB bus.
You may want to try using a DMA FIFO to pass data down to the FPGA.  You will have to add overhead to state what the data is as you pass it down (ie build up a message and send the message through the FIFO).
(1,487 Views)
Noted. I appreciate the help.
I will leave things the way they are - maybe when we get our production hardware [PXI chassis and junk], the Read/Write Control function will be faster with that configuration.
Either way, the 4ms isn't killing me, but that single call slows down my main thread by a factor of 2' all because of one call.
Thanks again!
(1,485 Views)
