NI USB LABVIEW to c++
I am a rookie in labview but I have a project, to get data (sound) from NI USB, then find the peak of the signal in which frequency.
after that I have to send the value of the amplitude to the bluetooth.
I want to use labview until find the peak of the signal (because easier using labview), after that I will use C++ to send the value to the bluetooth.
Is it possible?
Thank you
(3,803 Views)
Compile the C++ program into a .net assembly and call the functions from a .net node in LV.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(3,800 Views)
Thank you Yamaeda.
If I do it like that. So the "main" is in the labview?
Can I "include"the labview program to c++ program?
(3,770 Views)
Accepted by limavolt
Is it possible?
Thank you
Yes this is definitely possible.
I would ask (aside from being new to LabVIEW), why not just do the bluetooth communication in LabVIEW as well?  Unless there are some kind of C++ libraries that you cannot live without, it should be easy enough to do this all in LabVIEW (in most cases).
But yes, you have a few ways to call C++ code from within a LabVIEW application or vice versa.  To call it from within LabVIEW, I would make a DLL out of your C++ code.  If you want the main code to be C++ based, you will likely use ActiveX or a LabVIEW built DLL.
References to help get your started:
For LabVIEW calls within C++:  https://forums.ni.com/t5/Example-Program-Drafts/Calling-LabVIEW-VIs-from-Other-Programming-Languages...
For C++ calls within LabVIEW: http://www.ni.com/white-paper/4877/en/
EDIT:
Heck, if you really wanted to be crude you could just write two applications and communicate via TCP.  You have many options 😄
If someone helped you out, please select their post as the solution and/or give them Kudos!
(3,753 Views)
Thank you for your information,
I have try to send the information to the bluetooth, but unfortunetly the communication have some protocol which do not writen well (someone else did the hardware) and there is a C++ program which can communicate with this device.
(3,735 Views)
