NI Update service going into error
Hi
NI Update service going into error when trying to download updates. It happens on two different PC and versions of NI update.
Thanks in advance
/Bjarne
(1,205 Views)
Hi Briton,
Did you check this article before? There is well described solution in his case.
Regards)
(1,048 Views)
@l.hovs wrote:
Hi Briton,
Regards)
That appears to be a very different issue than what the OP is reporting.  But it is good information for me to file away for future use.
Bill
CLD
(Mid-Level minion.)
(1,032 Views)
Hi
Thanks.
The issue was solved by NI support. I don't know what it was, but it was something at NI side.
Regards Bjarne
(1,017 Views)
