Timed Structure and Dynamic Dispatch VI reentrancy
From what I understand, in LabVIEW you can not set dynamic dispatch VIs to preallocated clone reentrant execution; otherwise, you would get an error message. However, looking through the NI document (https://www.ni.com/docs/en-US/bundle/labview/page/reentrancy-allowing-simultaneous-calls-to-the-same...), it says that Timed Structure can override the reentrancy of any VI within the structure to preallocated. My assumption is the Timed Structure will not override the reentrancy of dynamic dispatch VIs, but it's not really clear in the NI document. Is my assumption correct?
Message 1 of 1
(779 Views)
