NI VISA error
 What does-it mean?
(3,138 Views)
I don't have complete information nor operational knowledge about NI-VISA Server, but AFAIK and can guess it is an application (maybe a service) that allows programs running on other LAN nodes to control instruments by means of VISA as if the instruments would be directly connected to the client PC. NI-VISA Server listens for client connections on TCP port 3573. But on your computer there is already a program or service that uses this port. Hence the error message. If you have installed VISA Server but don't want to use it, you may simply uninstall it.
Paolo
LV 7.1, 2011, 2017, 2019, 2021
(3,110 Views)
Could it also be due to firewall blocking?
Bill
CLD
(Mid-Level minion.)
(3,048 Views)
@Bill, you're correct, it is a port used by NI-VISA and it must be open.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000001DdxbSAC&l=en-US
https://www.ni.com/en/support/security/configuring-software-and-hardware-firewalls-to-support-nation...
Santhosh
Soliton Technologies
(3,025 Views)
No, because applications know nothing about blocking. Actually, the firewall (nearly?) always blocks connection attempts coming from other nodes. Another program on the same machine would be able to connect.
Paolo
(3,009 Views)
If you see an NI VISA error, first check the device connection and resource name. Make sure the right driver is installed and try updating it. Restart NI MAX and send *IDN? to test communication. If it still doesn’t work, share the error code for more help.
(2,121 Views)
