NI VISA in windows 10
I am not able to configure NI-VISA for Windows 10. Can anyone help me with it?
Thank you in advance!
(9,027 Views)
What version did you install and what are you trying to configure? What error message do you get?
(9,009 Views)
Hi Dennis,
I am trying to communicate with my USB device (which is MSP430), I didnt get .INF file for Windows10, may be because of that i am not able to see my device on NI VISA devices. And i have NI VISA 5.0
Thank you for replying!! 🙂
Supreet
(8,955 Views)
That's a very old version of NI-VISA and it is not supported on Windows 10. The first thing to do is to install the correct version - http://www.ni.com/download/ni-visa-15.0.1/5693/en/
Your version of LabVIEW must be compatible as well. If you have an older version, it might not work with the current version of NI-VISA or with Windows 10.
I have no idea about your instrument. The vendor should be providing it's driver for the USB connection. The driver will need to define the port as either USBTMC or as a virtual serial port in order for it to be seen in MAX.
(8,945 Views)
Hi Dennis,
Changing the VISA software version did work out. Thank you so much! Also, can u suggest any tutorials where i can find sample codes using NI-VISA. I am actually trying to read the voltage variation because of obstacle in front of my sensors and display on LabVIEW. And, i am using MSP430 board as my controller board.
Thank you for your help!
Supreet Juneja
(8,897 Views)
Look in the LabVIEW examples under VISA - there are many examples built into LabVIEW.
(blog)
(8,893 Views)
