NI-VISA (no access permission)
Accepted by krispiekream
It should be Control Panel -> Add/Remove Programs
Select NI software and then remove the NI-VISA and any other Drivers which are mismatched from your working system.
Then reinstall the same versions that are on your working systems.
Message 11 of 12
(983 Views)
i think i solved the problem by removing the ni-DMM functions on systems that doesn't uses this card.
Krispiekream
Message 12 of 12
(974 Views)
