NI-VISA with 32-bit vs. 64-bit
Hi All,
Just want to throw this out there. Has anyone else experienced issues using NI-VISA VIs in LabVIEW 2017 (64-bit)? I tried reinstalling NI-VISA, making sure I had all the drivers installed, etc. with no luck -- always getting error code -1073807202, saying I'm missing some library. BUT, when I run the same code in 2017 (32-bit), it runs fine. I assume I should be able to use VISA VIs in either version, so maybe it's just a bug?
Thanks!
Michael
(4,418 Views)
Was your order of install:
  1. LabVIEW 32-bit
  2. VISA drivers
  3. LabVIEW 64-bit
If so, you will have to re-install the VISA drivers for the 64-bit install. Make sure you install the development support for LabVIEW 2017 64-bit.
(4,411 Views)
Hi gregoryj,
As I recall, I installed LabVIEW 64-bit first.
Then, when I went to install the VISA drivers, it coerced me to install LabVIEW 32-bit also.
I'll try reinstalling the drivers once more though.
Thank you,
(4,397 Views)
