NI VISION toolkit v6.1
hello
I've bought and use NI VISION toolkit v6.1 by labview v7.0 but there is a problem to use it in labview v7.1 and v8.2.1
do you have any experience about this problem?
thanks for demonstration
(2,723 Views)
NI Vision 6.1 is only compatible with LabVIEW 6.1, 6, and 5.1.  Here is a link that shows all of the versions of the Vision Development Module and the versions of LabVIEW that they are compatible with.  I hope this helps.
GG
(2,709 Views)
I wouldn't be too upset about needing to upgrade, the versions after V6 are a lot easier to use...
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,701 Views)
