NI-Vision IMAQ Find Circular Edge
I got a some proble with the fonction find a Circular Edge of LabView Vision.  The problem is when the fonction found my circle he put a red circle, This is good ! but when I move the object for try to track the point, all the old red circle won't disaper.
After i while its pretty messy in my interface.
I got a image of the problem.
I want to know how to erase all the circle a each iteration.
Thank you
(3,488 Views)
Accepted by PIOU123
Hi PIOU123,
To clear the overlay use the IMAQ clear overlay VI. An example of this VI in use can be found by going to Help>>Find Examples and then navigating to Toolkits and Modules>>Vision>>Geometric Matching>>Geometric Matching.VI
Paolo F.
Applications Engineer
(3,461 Views)
Thank you for your advice
Piou123
(3,434 Views)
