NI XNET function palette not showing
Hi everyone, I'm having a situation installing XNET toolkit on a machine, I installed Labview 2012 SP1 in two machines that will use this toolkit, then installed XNET 15.5, both machines are windows 7 64 bits, in one machine the toolkit was installed correctly, I can see the function palette in Measurement I/O ---> XNET, but in the second machine, after installing, the function palette is not showing, I uninstall everything and start from scratch and still not showing, I installed XNET 20.5 and still not showing, NI MAX shows that the toolkit is installed, the folder and DLL is in the same path as the other machine, I tried install it manually but it throws an error that says that the toolkit is already installed, does anybody knows what can be happening or what are we doing wrong?
Regards
(3,083 Views)
Hi JMBstrd,
I am facing the same issue. Can you please post the solution, if it it fixed.
Regards
Srinibas
(2,807 Views)
Hi, it seems that you have to reinstall drivers and select a different version of XNET and see which one works, I re-installed labview again and XNET 19.5 and worked.
Regards
JMB
(2,801 Views)
Thank You, JMB
I believe Only XNET reinstallation 😀 will do the work. We don't have to  reinstall LV Again😥
Regards
Srini
(2,796 Views)
Had this issue with another system too.  Uninstalling xnet didn't work.  Had to uninstall LabVIEW too.
(1,606 Views)
