NI drivers affecting laptop wireless card
Several people from my organization have now mentioned that National Instruments driver installations are affecting their wireless card functionality.  In my case, it was the NIDCPower install.  The result is that the wireless connection will not turn back on after the PC has gone to sleep, eventually forcing a PC restart.
Is this a known or reported issue?
(3,006 Views)
Interestingly you're not the first to run into this problem - Labview2017 will disable my wifi connection
What software versions are being installed? OS version?
Certified LabVIEW Architect
Unless otherwise stated, all code snippets and examples provided
by me are "as is", and are free to use and modify without attribution.
(2,975 Views)
Yes, that situation mirrors mine and others.  I've experienced this on two different laptops now with Win7 and 10.  My colleagues would also have different hardware and configurations.  I'm currently using the Intel(R) Dual Band Wireless-AC 7265 adapter.
What is the best method to report this directly to NI?
(2,955 Views)
Accepted by JBrew
Go to Support.ni.com, find the Service Request Manager, and log your Support Request.  Note you need an NI Logon to do this (which you would have if you installed and activated LabVIEW on your PC).  Then follow the instructions.
P.S. -- if there are already two reports here on the Forum, odds are that NI knows about this, but if you log it, they can confirm that this is so ...
(2,951 Views)
Thanks.  I've reported this as a bug.
(2,944 Views)
