NI myRIO fast fourier transform (FFT) for microphone
Hello guys,
I want to run a FFT using the A0/I of the NI myRIO 1900 to measure the frequency of the input which is acquired with a microphone. Previously, a myDAQ was used and the FFT worked perfectly but I can't make it work on the myRIO. I am a beginner and have been stuck with this for a while now, that's why I would appreciate your help.
1. Question: Do I need to change the personality of the myRIO to high throughout with n-samples for creating a spectral analysis FFT or is 1-sample sufficient using arrays?
I tried to use the default FPGA personality of the myRIO with the following labview blocks but the input signal frequency is not detected...
2. Question: If using the 1-sample personality and the labview blocks shown above should give me the desired result... Am I still missing something that is causing the FFT to fail?
Thank you in advance for your help.
(2,109 Views)
Accepted by topic author lpfy
I found the solution in the mean time.
N-samples were required and here is the working FFT block diagram.
BR lpfy
(2,028 Views)
