saving labView waveform.vi data in a 2D array
I have created an oscilloscope VI that takes input using DAQ Assistant and displays the waveform. What should I do if I want to save my waveform in X,Y format in an Excel or Text file.
PS: I am new to LabView a detailed explanation will be appreciated or correction in attached VI.
(2,212 Views)
Hi akriti,
When you want to save a waveform you might try the WriteWaveform/ExportWaveform function found in the waveform functions palette…
Why do you think it is a good idea to convert a waveform to a 2D array using an ExpressVI ("FromDDT")? Why do you expect more than one channel in that 2D array when the input is a scalar waveform?
Why does your filepath contain so many SPACE chars at the end?
(2,183 Views)
Sir, I could not find the vi you are saying. Also I am new to LabView so please bare with me. I am attaching the vi, if you can kindly make changes to it.
(2,157 Views)
Hi akriti,
in your last VI you set a samplerate of 2MHz: I recommend to use the file writing routine already built into DAQmx!
Use DAQmxConfigureLogging to create a TDMS file for your DAQ task. This TDMS file will contain the samples as well as information about samplerate…
So you didn't find the Waveform functions palette? And you didn't find its FileIO subpalette?
Anyway: when reading samples at 2MS/s I don't recommend to export waveform datatype to files. Use TDMS instead, especially the TDMS write built into DAQmx!
As you are new to LabVIEW: did you notice those "Training resources" at the top of the LabVIEW board?
(2,142 Views)
