NI service update encountered an error
NI Update service encountered an error validating the integrity of one of the selected updates.
  1. Trying to update LabVIEW 2018 with a latest patch release
  2. Fails
  3. Resume
  4. Fails
Additional question:
Why doesn't NI package manager show there is a new update for LabVIEW environment but NI update service shows it?
NI System Configuration:
- NI PXIe-1071, 4-Slot 3U PXI Express Chassis , 1 GB/Slot throughput, Part Number: 781368-01
- NI PXIe-PCIe8381,x8 Gen2 MXI-Express for PXI Express Interface,3m, Part Number: 782522-01
- PXIe-5160 PXI Oscilloscope, 500 MHz, 10 bits, 2.5 GS/s, 2 Channels, 64 MB, Part Number: 782621-01
- Astronics PXIe-1209 2-Channel, 100 MHz PXI Pulse Generator, Part Number: 785033-01
(3,210 Views)
I am having the same problem, so look forward to seeing a response.
(3,175 Views)
Asukumari, are you able to download the latest patch directly from the NI website manually? I don't know a good solution to the issue of NI Update Service not behaving correctly, currently - but a good band-aid is to download it directly.
LabVIEW 2018 SP1 (64-bit)
(3,161 Views)
I already tried to do that, download the latest patch 2018-f2 patch 64-bit and install it, it won't succeed. If I remember correctly the error message was, you need to have LabVIEW 2018 installed first to apply the patch or something along the lines as such.
(3,152 Views)
Asukumari, can you confirm which version of LabVIEW you're using? (Open LabVIEW -> Help toolbar -> About LabVIEW...)
I'm just curious if there's some weird compatibility issue that hasn't been patched yet.
(3,138 Views)
