‎04-01-2014 04:19 PM
Dear NI
Today I bought a NI usb 6008 data acquisition
and i am using labview 2011
the problem is appear when after i end the configuring process of the I/o data acquisition assistant
the following picture shows the mxwcgoutrunsilent.VI is missed and a error happend
can any one help to provide such VI for me
also what is the complete labview modules so can i able to make a real time data acquisition
best regards
Solved! Go to Solution.
‎04-02-2014 10:47 AM
mangood,
Do you received an error code? If so, what is it? What version of the NI-DAQmx driver do you have installed? It seems your driver potentially installed incorrectly, and you may need to reinstall the driver.
Here's the link to the latest version of NI-DAQmx: http://www.ni.com/download/ni-daqmx-9.8/4297/en/
‎04-02-2014 01:02 PM
@hnesmith wrote:
mangood,
dear
i downlaod the 9.5.5 but its still not work for LV 2011
but i test it with LV 2012 and its work
do i make the thread open or make it as solved
‎04-02-2014 03:08 PM - edited ‎04-02-2014 03:10 PM
Dear
I build this VI with lv 2012 to make an analog acquisition and the NI 6008 work very good with this VI
just an ask :: is the time delay block will control the sampling frequency ??? Also
is this VI complete or need other VIs to make the NI 6008 work all the time with out buffer or FiFo problems
‎04-02-2014 03:28 PM
‎04-02-2014 03:52 PM
@Dennis_Knutson wrote:
The time delay will NOT control your sampling frequency very well. You have hardware timed analog input and you should be configuring for that. Just look at the examples that come with LabVIEW.
i think today is not good for work
error massage when open any NI 6008 example
‎04-02-2014 03:52 PM - edited ‎04-02-2014 03:55 PM
Try re-installing DAQmx. This time pay particular attention to the install support for page of the installer and ensure it is configured to install support for LabVIEW 2011 and LabVIEW 2012.
I suspect that LabVIEW 2011 was not installed before DAQmx or some component that NI Device Monitor supports was not encluded in the install resulting in the devmon configure this device wizard blowing up.
Alternately unplug the 6008, open DEVMON from the system tray and "Clear all device associations" Plug the 6008 back in and when the devmon screen prompts you to do something choose "Do Nothing" and check "Allways do this"
EDIT: I just read your latest post. some install must have happened in the wrong order
Use the control panel add-remove programs to "repair" LabVIEW 2011, LabVIEW 2012, and DAQmx then reboot
‎04-02-2014 03:57 PM
thank you
