NI visa read serial looses a lot of data
A baud rate that high would demand short cable length and premium quality cables, I would think.  Are you sure the hardware isn't the issue?
Bill
CLD
(Mid-Level minion.)
Message 11 of 16
(781 Views)
Meaning that you should find some low capacitance cable with a matched impedance for the serial method being used.  (RS-232, RS-423, RS-485,...)
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
Message 12 of 16
(779 Views)
@RTSLVU wrote:
What's with all the "sync byte" stuff? I have never seen anything like that before...
SDLC uses Sync Bytes to frame packets. SDLC was an alternative to Ethernet developed by IBM back in the day. But it used a "7E" as the sync bytes so this is something different.
Ben
Message 13 of 16
(763 Views)
Thank you! This has solved my problem.
Message 14 of 16
(760 Views)
Sounds like you have only used ASCII message protocols.  When dealing with binary/hex/raw message protocols, you need to have a start character, some way to tell how long the message is, and typically a checksum or CRC or some sort.  This is more common than you would think since it is a more efficient protocol, just harder for people to understand.
GCentral
Message 15 of 16
(750 Views)
@crossrulz wrote:
... more common than you would think since it is a more efficient protocol, just harder for people to understand.
Not to mention "bit-stuffing" where the control characters are not allowed in the data stream so extra bits are stuffed in where needed to prevent those characters from appearing in the data stream.
Ben
Message 16 of 16
(748 Views)
