NI visa read serial looses a lot of data
I am sending a continuous serial data from a micro-controller to the PC via serial port at a baud rate of 1562500.
I noticed that my lab-view read vi attached below looses lots of the data packets that I am sending. When I went through the saved data I notice that the data in the receive buffer has been flashed in the middle of the transmission and all the synchronization is lost.I tried using various buffer sizes but it seems the program behaves the same.
The problem I have is quite similar to the following.
https://forums.ni.com/t5/LabVIEW/VISA-Read-continuous-serial-data-drops-packets/td-p/3580333
Here I have attached the vi I am using at the moment.
Message 1 of 16
(3,863 Views)
I think you read too slow.
you get only 1+2+18 bytes and write it into file with expressVI. In this case every iteration you open and close file. That takes much time.
try to measure loop period, I think it will less than need.
Or remove "Write to file " vi and check speed
Message 2 of 16
(3,856 Views)
Thanks for the reply. The problem is I need to log the data into a file, how can I log the data into file without slowing the read?
Message 3 of 16
(3,838 Views)
You should use open-save-close functions
Also you have 1000 bytes buffer. You can read longer data packets, but rare
Message 4 of 16
(3,835 Views)
Loses
Lose = not find
Loose = not tight
Message 5 of 16
(3,826 Views)
Accepted by topic author M.z779243
@M.z779243 wrote: how can I log the data into file without slowing the read?
Also look into the Producer/Consumer architecture.  The idea is you have a second loop that does the logging.  The data is sent to this logging loop via a queue.  This way your serial port loop can just do its process and let other (parallel) threads process the data however they see fit.
Now where to begin with the rest of your code...
1. No need for any of your local variables.  You can store the data in the shift registers you already have set up (but aren't using).
2. Get rid of that "Stop VI" function.  It is just like hitting the abort button and no clean up of your references (serial port, file, etc).
3. Even when you don't want to process the data, you really should be going through the read process to avoid the serial port buffer from filling up.  Just have the case structure around the queue I mentioned earlier to no pass the data on to the logging loop.
4. The FOR loop makes no sense to me.  Why not just constantly read the packets instead of forcing groups of 16 before writing to the chart?  Charts have a history, so you will still see all of the last X samples (X = buffer size, default is 1024) in the chart.
5. No need for so many Simple Error Handlers.  Just one at the end of the loop should more than suffice.
6. Your data conversion can all be done with a simple Unflatten From String.
7. Your structure in general is just a mess.  Here is a cleaned up version.
8. You can put all of your data into a single chart.
GCentral
Message 6 of 16
(3,823 Views)
I tried your suggestion but the problem still persists. Even though the saving happens much faster, I still have exactly the same UN-synchronization and lose a lot of data . The pattern seems to be first it reads 48 packets of data and looses a lot of packets thousands of them, afterwards it reads 772 packets correctly followed by a lose of 48 packets, After that it reads only every other 48 packets of data.
In addition to this the save function gives GpiB error after reading for a while.
Message 7 of 16
(3,818 Views)
You should study the shift registers.
You lost file reference after pause
Also you still read only 18 bytes. If you can't read more, use Producer/Consumer as crossrulz has said
Message 8 of 16
(3,804 Views)
My suggestion to you would be to read all data and save it to a separate file then go and review that data against your code.  I see parts of your code where you expel data that doesn't match your search criteria.  You may wish to keep that data and append the newly acquired samples to the end.
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
Message 9 of 16
(3,790 Views)
What's with all the "sync byte" stuff? I have never seen anything like that before...
What instrument are you communicating with? What is the format of the incoming data? Is there a termination character of any kind?
But as others have already said receiving data at such high baud rates you really need to use a producer/consumer architecture. The "producer" is a loop that will just receive the data place it in a queue (a buffer) and send it to the "consumer" loop. Now the consumer can take its own sweet time de-queueing the data and analyzing it as incoming data will simply stack up in the queue.
=== Engineer Ambiguously ===
Message 10 of 16
(3,779 Views)
