NI visa writes when serial port closes
@matt198717 wrote:
Hi Bill,
I actually cant find the power ratings for the hub, its a rosewill RHUB-500, some off the shelf thing I thought might work better than the native ports.  I would agree it could definitely be either power issues or enumeration issues with all the adaptors and then the hub.  I have an NI chassis with a PXI 8430/16. Im going to charge my devices for a few hours and then give that a try.  If the problem is fixed then it is either the adaptors or the hub. I ran a test similar to this with a lot more data transfer going on and 6 USB converters and didnt see an issue for around 3 weeks.
Rosewill (Newegg house brand) is cheap junk.
=== Engineer Ambiguously ===
Message 11 of 13
(1,005 Views)
@Sam_Sharp wrote:
While USB hubs are good for providing more power, they are not good for the reliability of the connection as you'd have all 7 devices essentially multiplexing through a single USB port for communications which could cause issues. The best solution would be to use a PCI or PCIe card with 8 serial ports, then either using a single usb to 8 serial port box or adding more USB ports via PCI/PCIe.
Did you try my suggestion about flushing the transmit buffer?
Hi Sam,
I am now going to use a chassis i have with a PXI 8430/16.  Its pretty much exactly what youre talking about.  I also did try your suggestion of flushing the transmit buffer.  Typically i flush the buffers when i open the port.  It didnt fix the issue though, even if i opened and closed the port for every write i performed.
-Matt
Message 12 of 13
(1,003 Views)
@RTSLVU wrote:
@matt198717 wrote:
Hi Bill,
Youre entirely right, but it was working better than the native ports on the desktop.  By no means is it an industrial piece of equipment, i just had it lying around and thought some external power might help.Ive got the PXI chassis out now though.  I assume i wont have any issues with it now.
-Matt
Message 13 of 13
(1,000 Views)
