NI9219 Force Transducer code with cRio-9063
I am using cRio-9063 with the NI9219 module to read force transducer measurements. I am struggling to find a code that will work with cRio as the majority of examples I have seen use myDAQ. The load cell force transducer I am using is the World Precision Instruments FORT100.
Are there any suggestion on what I can do?
(1,047 Views)
Hi MK,
Open the example finder in LabVIEW and search for examples for your NI9219 module.
(Keep in mind: you can filter by hardware in the example finder…)
(1,032 Views)
i have looked in the examples however in the example it uses a different cRio system to the one I am using and it won’t let me change it to the cRio-9063. Is there a way to do this?
Many thanks
(1,012 Views)
Hi MK,
create a new project, add your own cRIO as RT target, then add (a copy of) the example VI to your own project…
(1,004 Views)
