NI9234 sampling rate - LabVIEW FPGA
Hey guys,
I have very simple question. I am checking a sample code in labview examples for NI 9234. what is the difference between data rate and samples per channels?
If we read with maximum data rate which is 51.2 KS/s (reading 4 channels), so the samples per channel should be 51.2/4=12.8 KS/s/ch . am I right? if this is correct, what is the sample per channel control in the FPGA vi?
(4,268 Views)
Accepted by far_nia
The rate is how often a sample is taken by the a/d. The sample count is how many of those samples you return to the program. For example, if you had a rate of 1000 samples per second you could request 500 samples which would take 500 ms to acquire. At a rate of 2000 samples/sec, requesting 500 samples would take half as long. Keeping the same 2000 samples/sec and requesting 2000 samples, we are back to to 500 ms to acquire.
(4,257 Views)
Thanks for the quick reply. but could you please explain your sentence one more time: "if you had a rate of 1000 samples per second you could request 500 samples which would take 500 ms to acquire" where does this "500ms" come from? I am a little confused by your answer
(4,252 Views)
p.s. You adjust the sample rate to adjust the detail of the waveform you wish to capture. A rate of 2000 samples per second has resolution twice that of 1000 samples per second.
(4,250 Views)
It's just basic arithmetic. Doesn't it make sense that if you had a rate of 1000 samples per second and requested 1000 samples, the acquisition would take exactly 1 second? Time to acquire is number of samples divided by samples per second.
(4,240 Views)
got it!
(4,215 Views)
got it!
(4,210 Views)
