NI9401 output signal
I am currently uisng the CDAQ 9178 and the NI 9401 modules to generate the output signal. Currently I am testing out using the
Generate Finite Digital Pulse Train Retriggerable.vi from the NI example finder. The main problem i am facing is the I can generate a pulse but is unable to vary the frequency on the go. Meaning to say, whatever value i set initially will be taken as the fixed value in generating the pulse frequency. May I know what are the ways to generate an digital output pulse signal that has varying frequencies? up to around 100kHz?
Hope someone could help me thanks a lot
Jhao
Message 1 of 1
(2,369 Views)
