NI9411 - any counter logic?
in NI9411 - is there any counter logic in encoder signal?
(2,955 Views)
Hi there!
The specifications for the 9411 can be found here https://www.ni.com/en-us/shop/model/ni-9411.html
This does not contain any counters.
I hope this helps.
Liam A.
Applications Engineer
(2,931 Views)
Yeap!
I read the data sheets earlier, and I couldnt found any counter logic either.
Are you sure about this?
Thank you! 😃
(2,916 Views)
Accepted by Maybach
If you are using the 9411 with a CDAQ (the old version) then using slots 5 or 6 will allow you to use counters off the chassis. If you are using a CDAQ 2 (the new version), then any slot can be used as a counter. The 9411 itself does not contain any counters.
Please let me know if I can help further.
Liam A.
(2,905 Views)
Thanks alot!! 😃
I think You explained me enough 😃
(2,882 Views)
