NI9476 and PWM
Hi all,
for a project I have three NI-9476 module mounted on a Ethercat NI-9145. All the slot of the Ethercat module are occupied. In the third NI-9476 module I have some DO channel free.
My client wants to command 9 SCR lines with PWM using the DO free channels. Is it possible to uso only some DOs as PWM via FPGA? Is there some examples online?
Thank you very much.
Message 1 of 8
(2,454 Views)
Hi Penzium,
In the FPGA you can control each single DO channel as you like…
(Keep in mind the NI9476 switches rather slow.)
Message 2 of 8
(2,451 Views)
How slow? I have to generate a cycle time of 100Hz maximum
Message 3 of 8
(2,447 Views)
Hi Penzium,
Do you mind to read the manual of the 9476 module? It contains all the information you need!
The spec of the module mentions a 500us switching time, so this module only allows up to 2kHz. This will not give very accurate PWM at 100Hz cycle rate...
Message 4 of 8
(2,422 Views)
Sorry, you are right I could read the manual.
Thank you for all the info that you provide me. Probably I have to choose another way to generate the PWM.
Thanks.
Message 5 of 8
(2,372 Views)
Small update. I tried yesterday and I was able to command 6 SCR line in PWM with the NI9476 module so it seems ok to use this module to generate 100Hz cycle rate PWM.
Message 6 of 8
(2,345 Views)
Accepted by topic author Penzium
Hi Penzium,
as I wrote before: it's ok, but not very accurate…
(At 100Hz cycle rate you can only output PWM values at steps of 5%.)
Message 7 of 8
(2,343 Views)
Hi GerdW,
thanks for the response, I don't have alternative is an existing installation with no update possibility so I cannot change or install new module.
I think step of 5% should be ok for our purposes. I will have to control the duty cycle with a PID so I will have to take into account this limitation.
Message 8 of 8
(2,337 Views)
