How to use TraceListener
Hello
I have to implement the function TraceListener from the Windows System Assembly in one of my VI's to trace the outputs from another used .NET-assembly.
The Code in C# is:
TraceListener traceListener = new TextWriterTraceListener("ItacMII.net.log");
Trace.Listeners.Add(traceListener);
Trace.AutoFlush = true;
attached is my implementation in LV, but there will no output File generated...
Has anybody an idea where the failure is?
Best Regards Matthias
_______________
Automate LabVIEW builds easy with Jenkins Plugin www.kubes.ch/Jenkins
(3,882 Views)
it doesn't work because you have to choose as TextWriterTraceListner the constructor that accept the filename, as in the following figure.
Once you choose that you can add it directly to the collection of listeners.
Best Regards
(2,699 Views)
