NI9514 FPGA-Mode Minimal Example
Hi there,
I'm using a NI9514 Module in a cRIO-9075 chassis and i'm trying to get it to work in FPGA-Mode.
Is there any kind of minimal exmaple?
I simply want to give a Drive Command (bet −32.768 and 32.767) from the Host.vi and simply get an output between -10V and +10V from the module.
What steps are necessary to achieve this?
Greetings
Jaifraic
(5,304 Views)
Hi Jaifraic,
I just found a Folder with a few examples in LabVIEW You could look through to find the answer to Your question.
C:\Program Files (x86)\National Instruments\LabVIEW 2015\examples\CompactRIO\FPGA Fundamentals\FPGA Math and Analysis\PID Toolkit
You`ll find the examples if You use win7 . But if You ca'nt find them, please reply.
best regards
Pascal
(5,248 Views)
Hi Jaifraic,
I forgot to mention that the example I thought about specially is called "Using Discrete PID - cRIO"
BR
Pascal
(5,246 Views)
Hi PHejj,
thank you for your reply, but this is not quite what i'm looking for.
There is an example for the NI9514-Module (NI9514 Basic Move) and I tried to strip it down to get a minimal example, but i could not get it to work.
What I want to do is to set an output in the RT Host-VI and get an proportional output voltage  out of the FPGA-Module.
Greetings
Jaifraic
(5,222 Views)
Hi Jaifraic,
what is'nt working? Is it the compilation or the VI, or the hardware?
Or do'nt you get out the expected voltage?
Well anyway, I checked some knowlegebases and other cases that I think match up with Yours. The first Link shows options not supportet by NI9514. The others is two forum-threads and a How To.
NI 9514 (FPGA Interface) - NI-RIO Software Help 4.0 - National Instruments
http://zone.ni.com/reference/en-XX/help/373197B-01/target4devicehelp/9514_io_reference/
Solved: NI 9514 FPGA and SoftMotion - Discussion Forums - National Instruments
http://forums.ni.com/t5/LabVIEW/NI-9514-FPGA-and-SoftMotion/td-p/2173030
Sinusoidal move using contour move and NI9514 - Discussion Forums - National Instruments
http://forums.ni.com/t5/Motion-Control-and-Motor-Drives/Sinusoidal-move-using-contour-move-and-NI951...
How Do I Use the NI 951x Motion Control Modules in Slots 5-8 (Non High Speed Interface Slots) of my CompactRIO Chassis? - National Instruments
http://digital.ni.com/public.nsf/allkb/C43C73FE11BE740A8625763C006CC3ED
Best Regards
Pascal
(5,205 Views)
