need help
i want to make convert for 3 (control used diode & control used SCR), but i don't know how to design number for diode & trigger for SCR. someone help me please. Thank you for attention
(3,921 Views)
That is not really a LabVIEW problem. In addition there are multiple sites on the web that detail how to design with SCRs.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,916 Views)
Actually I just noticed the voltages you are working with. Don't play with that unless you know what you are doing. You could kill yourself or someone else. Hire someone who knows what they are doing.
Mike...
LabVIEW Champion
(3,913 Views)
Hi AWA,
some notes:
- Using "need help" as topic is as worse as possible: all people asking questions here need help…
- You're asking in a LabVIEW forum dedicated to use LabVIEW as programming language, but your question is about building some hardware (and using harmful voltage levels). That doesn't fit very well!
- When you are working with these voltages you should know how to design this circuit! If you don't know: call an electrician and let him/her do this type of work!
- It seems English isn't your mothers tongue (the same for me) so try to reword your questions after using some (better) translation tools: What "numbers" do you want to design?
(3,911 Views)
