NIDAQmx error self-test
Hi. I have a problem with the error when doing the self test on Ni USB-6221 in NI MAX version 4.2.0.3001 .
Please see the pic below.
This happens after I did all those things, Please see below:
1) I un-install NI-MAX 4.2.0.3001 because it is very slow in opening up tasks and device properties/tests.
2) I ran spybot - search and destroy, to remove hidden programs that may have slowed down
3) I install the new NI-DAQmx 9.0
4) I cannot find NI-DAQmx library functions in Labview 7,1, realising that the new version does not support LV7.1
5) I uninstall NI-DAQmx 9.0 and install NI-MAX 4.2.0.3001 (NI-DAQmx 8.5)
6) The pic (above-mentioned) shows up after reset test in MAX.
I used the same NI-USB 6221 in another PC (NI-MAX 4.2.0.3001 and NI-DAQmx 8.5) and it works after reset test.
Please advise what I should do.
regards,
Clement
(2,862 Views)
Hi For those who faced similar problems, do the following :-
Please follow the step in attached file to remove all NI software.
Then, reinstall them again.
After installing LabVIEW, re-install DAQmx.
I'd recommend you to install DAQmx 8.7.1, which is the latest version supporting LabVIEW 7.1.
regards
Clement
(2,843 Views)
