NIMAX generate report from command line
Dear users,
I would like to generate MAX report ("MAX Generate Report.vi") from command line. Does nimax.exe have this capability, or do I have to write a wrapper to vi ?
Regards.
Message 1 of 11
(5,955 Views)
Accepted by mpankau
There is possibility to do that from command line. You can see how to do that in document:
Documenting Measurement & Automation Explorer (MAX) Configuration Information
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q0000019hceCAA&l=en-US
Dawid
Message 2 of 11
(5,932 Views)
I believe it is possible to generate report from command line.
Check Documenting Measurement & Automation Explorer (MAX) Configuration Information.
Stefo
Message 3 of 11
(5,926 Views)
Great, thanks.
Regards
Michal
Message 4 of 11
(5,911 Views)
Giving Kudos and marking answers is always appreciated Smiley Wink
Stefo
Message 5 of 11
(5,890 Views)
hi,
when i run the command "C:\Program Files\National Instruments\MAX>nimax /REPORT:filename="C:\Reports\rep
ort.xml";reportType="simple";silent="false"" from command prompt, i am getting the error saying
"Runtime error
Program : C:\Program Files\National Instruments\MAX>nimax.exe
This application has requested the Runtime to terminate it in an unusual way. Please contact the application's support team for more information."
Please, let me know how to resolve this issue.
Note: NI Max version is 4.7
Ramjee V
Message 6 of 11
(5,415 Views)
Hi Ramjee,
I tried to replicate your problem, but I'm not getting the same error as you are.
I'm using MAX 4.7.7 and win 7 64bit.
Could you possibly try to upgrade NI MAX to the version 4.7.7 and could you clarify what operating system you are using?
Jano
Message 7 of 11
(5,380 Views)
I am using WWindows XP operating System.
Ramjee V
Message 8 of 11
(5,370 Views)
Dear ramjeev
to solve your problem you can try two aproaches
1. instal new verzion of MAX
you can download the newest verzion of MAX from the link
http://joule.ni.com/nidu/cds/view/p/id/2328/lang/en
This distribution includes the following products:
NI System Configuration 1.2.0
NI Measurement & Automation Explorer 4.8.0
NI Network Browser 1.1.0
2. clean up corrupted max database and start with new one
you have a step by step solution on the link
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P8awSAC&l=en-US
Hope it will help you.
Message 9 of 11
(5,344 Views)
Is there any API to generate the same NI MAX report from LabWindows/CVI?
Ramjee
Message 10 of 11
(5,309 Views)
