NIPALU.dll not found
I need the aplication NIPALU.dll because the program labview ask me that.
(3,240 Views)
NOTE: The above question was originally posted here and it got moved to the LabVIEW board for obvious reasons. Parts of my answer require this context.
Is this in any way related to my presentation (doubt it!) or a general problem when you try to run LabVIEW. According to some other discussions here, you are most likely using Avast antivirus which seem to interfere here (false positive!). Switch to a better antivirus, reinstall LabVIEW, and try again.
Please post in the LabVIEW forum unless you only have this problem when opening my code. Also be more specific about e.g. LabVIEW version and OS, etc. Provide as much detail as possible. Maybe show the exact error message.
(3,207 Views)
